DXCC.rsd
K6LE
DXCC.rsd
Unread post by K6LE »
I noticed that the beam heading for A5 Bhutan was completely wrong for my location.
In checking my DXCC.rsd file the Grid locator for A5 showed as KN13MA which is in Europe. I changed it to NL57IO and now get the correct heading.
I don't know if this was a fault with just my DXCC.rsd file or others.
BTW, Tom, Thanks for the easy way that DXCCEdit allows us to edit that file.
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
Re: DXCC.rsd
thanks for the hint Rick. I guess, there are some more failures. It is a good practice to have the gray line map window open. After entering a call, you see the default location.
Is YJ shown correct? There was a failure as well.
K6LE
Re: DXCC.rsd
Good tip on checking the Grayline Map.
No, YJ was wrong also. I changed it to RH34MA.
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
