Wrong Last Spot
EI7JZ
Wrong Last Spot
Unread post by EI7JZ »
Hi Tom.
I figured out that if you log a QSO with a wrong callsign, select the QSO and edit it (changing the callsign to the correct one) and hit enter again it will be shown correctly in the logbook table. If you now decide to send the last spot (Ann. Last Logged QSO), the original (previous) callsign will be used.
By-the-way, is there a possibility to get a summary (like in the DXCC list, worked/confirmed) mainly for IOTA and DOK (but it would be nice for the other awards like CQ, ITU and States as well)?
Claus, EI7JZ
Re: Wrong Last Spot
Hello Claus,
tnx for the info, I will correct this in the next update.
Currently I have not the time to implement new features, only bug fixing is possible. I will keep it in mind for the future.
