Clublog realtime upload from ADIF
BG4SE
Unread post by BG4SE »
I found my QSO import from ADIF cannot be uploaded to Clublog in realtime. It is just saved to RUMlog only. But the clublog realtime synchronisation is OK for QSOs imported via N1MM, WSJT-X, or "logbook -> import ADIF/ADX".
It can be uploaded successfully via "logbook -> upload new QSOs to Club log" too. I just wonder is it normal?
Thank you.
Re: Clublog realtime upload from ADIF
After an import QSOs will be uploaded but the real time API is not used.. The QSOs are queued in Club Log awaiting processing. Check the Club Log status information above the Station Info Box.
BG4SE
DL2RUM wrote: ↑Wed 29. Jul 2026, 12:55 After an import QSOs will be uploaded but the real time API is not used.. The QSOs are queued in Club Log awaiting processing. Check the Club Log status information above the Station Info Box.
Oh sorry, I mean that one "QSOs received from Flex/ADIF".
When I use JTDX log a QSO, the one imported from WSJT-X format is uploaded to Clublog in realtime, but that from ADIF format isn’t.
This should work as well in real time, but I can't confirm it right now.
Check the Club Log status above the Station Info Box
Check the messages in the Network status Window.
BG4SE
DL2RUM wrote: ↑Wed 29. Jul 2026, 17:53 This should work as well in real time, but I can't confirm it right now.
Thanks, I have already checked it. When JTDX send the WSJT-X format message all things go well. It says "Club Log: QSO Duplicate - OK". But when I only use the ADIF format, the Club Log status remain the message before.
And I can see the back of "logbook -> upload new QSOs to Club log" telling me that there's a QSO not uploaded yet.
Today I was able to test it and I can confirm the problem. The problem was a bit complex and the error was easy to overlook. It will be fixed in the next update.
Tnx for the hint.
