Cluster: Send Locator
EA4AAE
Unread post by EA4AAE »
Hi!
I´ve got programmed a macro as "DX %LastCall %LastQRG IN80EJ <> %LastDXLocator".
In the list the locator has 6 digits (IN80EJ as example) but when I use this macro the
"%LastDXLocator" only use the first 4 digits (IN80 as example).
I don´t know if i have any error.
Thanks in advance,
73s
Javier Coso
EA4AAE
Re: Cluster: Send Locator
Well, only the first 4 characters will be send. There was reason, but I can't remember. :(
I discussed this with a friend who asked for this and we decided 4 characters are quite enough.
Do you want to have all 6 characters?
EA4AAE
DL2RUM wrote:Well, only the first 4 characters will be send. There was reason, but I can't remember. :(
Hi!
I think if the user use 6 characters for the locator it should send the 6 characters as if the user
use only 4 characters it should be sent the 4 characters.
What about this?
73s
PD: The mode on computation for 6m is working fine!
TIA
Javier Coso
EA4AAE
Okay, I added %LastDXLocator4 and %LastDXLocator6 as variable, so the user has the choice. %LastDXLocator ist still available to remain compatible.
The problem is that I can't upload it yet, because I'm out of the country and have a very limited internet connection only.
EA4AAE
DL2RUM wrote:Okay, I added %LastDXLocator4 and %LastDXLocator6 as variable, so the user has the choice. %LastDXLocator ist still available to remain compatible.
Many thanks, and don´t worry because you can´t upload it now. It´s for the next revision, we can wait for it!
TIA
Javier Coso
EA4AAE
I made it and it took just two and a half hours. :roll:
http://dl2rum.de/rumsoft/RUMlogApp.zip
EA4AAE
DL2RUM wrote:I made it and it took just two and a half hours. :roll:
Many thanks. I never thought it could be so hard!
73s
Javier Coso
EA4AAE
EA4AAE
Hi again!!!
I´ve been testing the "%LastDXLocator6" but I think there is a little
problem. At least, my computer take the variable "%LastDXLocator6"
as "%LastDXLocator" and then add a "6". I mean if I´ve had a locator
as "IN80ej" it takes it as "IN806".
My macro is:
DX %LastCall %LastQRG IN80EJ <> %LastDXLocator6
TIA
73s
Javier Coso
EA4AAE
Well, there is a bug and the %LastDXLocator6 variable is useless. :( :( :( No problem to fix that, but I can't upload it yet. Maybe in the first week ion August.
EA4AAE
DL2RUM wrote:Well, there is a bug and the %LastDXLocator6 variable is useless. :( :( :( No problem to fix that, but I can't upload it yet. Maybe in the first week ion August.
Hi Tom.
Thanks for resolving the fix. The time is not a problem. I´ll do it by hand. Je je je.
TIA
Javier Coso
EA4AAE
