Mode SSB; not taking from radio LSB or USB
PD2FT
Unread post by PD2FT »
I am new to RUMlogNG. I had initially set things up on PC (Log4OM) to get started, but wanted to log my QSOs on my MacBook Pro instead. On Log4OM I am used to that when I log a QSO automatically also right SSB mode is picked, so LSB or USB. On my install of RUMlogNG, this is not working. Also not when I am double clicking a callsign in the bandplan; my radio goes to the right frequency but RUMlogNG is every time showing SSB. I was wondering what I am doing wrong, or how I can tune things that right SSB mode is automatically recorded in a saved QSO. Now, I often have to correct in my log and the QSOs forwarded by QSO upload utility to QRZ also there so it is somewhat inefficient.
My set-up is MacBook Pro M1, Yaesu FT-710 via USB connected to a 1-4 USB hub.
In Settings / TX-1 I have set:
- Use CAT = ticked
- XVTR offset = 0
- Manufacturer = Yaesu
- Type = FT-710
- Interface = Serial
- For PTT use = Do not use
- For RTTY use = Data USB
- For PSK use = Data USB
- For unknown Data use = RTTY
- Poll interval = 1.0s
- No CAT: TCP settings set
- No CAT: Bluetotth LE settings set
- No DxLab Suite Commander settings set
- CAT: Serial:
- Serial port = usbserial-01A99AF20
- Baud rate = 38400
- Stop bits = 1
- Parity = None
- Flow control = Nothing set
- Power up lines = Nothing set
Settings / QRGs : nothing changed
Modes/Sat: only selected FM, FT8, SSB, LSB, USB
Thank you in advance for your support! 73
Re: Mode SSB; not taking from radio LSB or USB
RL saves the mode (SSB) only, when the data comes from the transceiver. If you want to log a submode, (LSB, USB) you have to enter it manually.
PD2FT
OK, thank you for the blazingly fast reply!
Would it be possible to refine in a next update as the CAT-message/reply from Yaesy FT-710 gives that information; P2 MODE gives 1 in case of LSB and 2 in case of USB?
Thank you and 73
No, I don't see a reason to change this thing.
