Rotor Operational Questions (vk4ma)
Posted: Wed 5. Nov 2025, 04:23
Hello All
I have recently started using Rotor after moving my shack to MacOS - a few things are not clear to me
1 I have two rotators (both AlfaspidRAK), when using the Rotor App, my 6 metres antenna rotates through 0 degrees - ie if I am at 5 degrees and want to rotate to 355 degrees - the rotor will move anti clockwise and move just 10 degrees. With my HF antenna, the rotator wants to rotate through 180 degrees so it will move clockwise and rotate a full 340 degrees to get to 355 degrees. I can not see a setting in Rotor that controls this (nor in the manual for the Alfapid). Both rotators were swinging through 0 degrees when using PST Rotator. Any ideas as to what is wrong here?
2 In the turn box - it says you can post numerical direction, grid or call. If I put in say 320 the rotor will rotate to 320 degrees. But if I put in a full callsign or a dxcc prefix the rotator does not move. How do I get the "call" functionality to work so I can put in a callsign and the rotator turns toward that callsign location? I am using Rotor stand alone - ie not connected to Rumlog - is this the problem?
Any help is appreciated
Cheers and Thanks
Paul - vk4ma
Cheers and Thanks
Paul - vk4ma
