Populate QRZ.com information after Tab pressing
sp2as
Unread post by sp2as »
On RUMLogNG on macOS when you type in Callsign and press Tab it populate from QRZ.COM some information like Name or QTH. I found that in RUMLogNG2Go on iPad it is not working that way. I need to touch "QRZ", switch to new view and then go back to log view (just to see name and QTH). Is it possible to make that iPad version will behave like macOS version in this regards?
73, SP2AS, Arek
sp2as
Re: Populate QRZ.com information after Tab pressing
I reply myself. I found old Tom message that he is not liking this approach. OK, I understand that. Maybe just add shortcuts in iPad version for those using phisical keyboard to fastly switch to qrz? Actually we need to use finger to touch the screen which is time consuming. In my ideal world I would like to have three shortcuts:
1. To fast use „qrz” button from Logbook view
2. To fast use „Use Data” button which will also switch back to Logbook view
3. To fast use „Close” button to switch back to Logbook without using qrz.com data
What you think about this idea?
73, SP2AS, Arek
