RumlogNG date sort problem?
todivefor
Unread post by todivefor »
I imported 3 adif log entries. The first one was about 2300 UTC May 1 (highlighted in screen shot). The other 2 were after 0000 UTC May 2. After importing I thought I was missing a log entry until I found it further down the log. It is not a big deal as it appears to be logged correctly, just in the wrong order, should be third entry in log.
https://www.dropbox.com/scl/fi/ui3ki1c3 ... mlk5k&dl=0
Re: RumlogNG date sort problem?
When you have set the option to save the QSO end time, the log will be sorted by the end time, not by the beginning time.
