Page 1 of 2
cannot print qsl labels QL 700
Posted: Sat 22. Feb 2025, 12:56
by Jacques
Hi new to RL I wish to set up the print qsl labels to a brother QL 700 with 90X29 mm labels (used before with HRD) I have read and gone through post with out success. The Brother QL700 works well for labels if used independently . Please any help welcomed
Re: cannot print qsl labels QL 700
Posted: Sat 22. Feb 2025, 20:11
What is your problem/question?
Posted: Sat 22. Feb 2025, 20:46
by Jacques
I believe I did all the correct steps as shown in the previous post yet nothing prints . yet if I print a label from the label software (P-Touch ) it works fine..
It appears that what happens is when sending to print is broken between RL and tenQL 700
Posted: Sun 23. Feb 2025, 07:21
You should Print to PDF first to see what is going wrong.
Posted: Sun 23. Feb 2025, 10:22
by Jacques
That made no difference still will not print on QL 700 label printer
printing on to my regular HP printer on A4 I get the qsl data printed ok but on A4 paper
surely someone must use a label printer with rumlog ?
Cheers
Posted: Sun 23. Feb 2025, 20:38
Then you haven't selected the correct paper format: https://dl2rum.de/RUMlogNG/docs/en/page ... Print.html
Read the first paragraph very carefully.
Posted: Mon 24. Feb 2025, 08:06
by Jacques
Hi Tom I appreciate your help but I have read all of this and for a start te menu does not correspond to what I have .
eg Menu–>Edit–>Print Setup is Menu–>Edit–>Print and there I get photo 1. and from there cannot set all borders to 0
if I go menu page set up I get photo 2
found user define and set 0 photo 3
Paper qsl out gives Phot 4
when hit print I get photo 5
but nothing prints
sorry but there is something I don not understand so far this is the only soft that I have not be able to configure the QL700 running a roll of DK 1104 90x29 labels to stick on qsl card
anyway I am off to hospital for a quick operation so will worry about that later
Thank
Posted: Mon 24. Feb 2025, 11:21
Works fine here.
Print.pdf
(26.99 KiB) Downloaded 955 times
Print.pdf
Posted: Mon 24. Feb 2025, 14:27
by Jacques
hi while waiting to be operated :-( Great I see it works for you but that does not solve my issue I need to see what are you steps Cheers
How to print QSL ? on RL 5.19.1 (678)
Posted: Thu 27. Feb 2025, 09:19
by Jacques
Hello well no news from anyone so still cannot print labels to QL700 roll or to HP envy on A4 paper or label paper . I have gone through help so many times but there must be something I am missing since the titles shown in Manuel on help does not read the same as on teh soft
e.g. manual Menu–>Edit–>Print Setup . in software its just print and non of the photo example match so at a loss
in qsl setting I have selected Dymo 29x90 when actually using brother DK 11201 labels 29x90 on the QL 700 though I do not see how that can affect the reading etc
so if someone can please walk me though this I would greatly appreciate it, if it can print on the QL 700 fine then I can get some A4 label page for the HP printer but again how to set up etc .
I hope this can be sorted. out I really do not want to look for alternative source
Thank you all
