RUMlog 4.4
RUMlog 4.4
Version 4.4 is ready for Download
  • Digital Window added, work RTTY and PSK direct in RUMlog - Menu-->Digi
  • K3 Control Window added - Menu-->Transceiver-->K3 Info
  • Multiple dx-cluster connections are possible, connect now to your local skimmer - Menu-->Window-->New Telnet Cluster
  • LoTW users are indicated now in the Station Info box
  • User downloadable LoTW User database - Menu-->File-->Load LoTW User Database
  • Direct eQSL upload, upload your log with one mouse click Menu-->QSL-->eQSL Direct Upload
  • Disconnect Radio command added, useful if you want to connect your radio temporally to another application - Menu-->Transceiver-->Disconnect
  • Greek and Spanish localisations (Partly) - tnx Manos, SV1DAY and Jonathan, EA1HET
We are still looking for other translators
See http://dl2rum.de/forum/viewtopic.php?f=4&t=142
RUMlog.app and RUMrouter.app were changed. RUMrouter.app is required for microHAM MKII owners only.
Re: RUMlog 4.4.3
We are now at bug version 4.4.3 Tnx to the OMs, reported the failures.
It seems to me, all rendering problems in the html based windows are fixed. (Sun data, qrz.com) Please do an intensive test and report!
New: FT-950 confirmed functionally, use the FT-2000 setting
Bug fixes:
  • RUMrouter doesn't start now when not required
  • Some rendering failures in the Main Window removed
  • HTML based windows rendering failures removed - long history
  • K3 power indication corrected
  • All windows should show the Menu bar now
M0JEK
Re: RUMlog 4.4
Unread post by M0JEK »
I have just tried the latest RUMlog, Tom. You have done a great job adding the PSK and RTTY functions to RUMlog, with CAT control for PTT! Wonderful.
I haven't used it in total anger yet, just tested the PSK and RTTY and had a quick look around (I need to be up early for work).
I am glad to say, all still works with my FT-450 :-)
I did notice when I switch to RTTY, the waterfall / spectrum display started flickering. It is fine if I switch back to PSK modes. I will try again tomorrow to be sure.
Again, RUMlog has just got better again! :-) Thank you Tom.
73 de André, M0JEK
M0JEK
Re: RUMlog 4.4 - Apple Script question
Hello Tom,
Now that RUMlog 4.4.x has the capability of PTT via CAT, I was wondering if it would be possible to add Apple script support for the PTT control via RUMlog.
What I would like to be able to do is to have cocoaModem call an AppleScript program to drive PTT through the RUMlog CAT feature when I am using cocoaoModem in standalone mode, such as when I am using a modem which is not supported by RUMlog yet, such as Hellschreiber.
Another advantage of it this way is that one only needs the one serial port ... :)
Thoughts?
73 de André, M0JEK
RUMlog 4.4.4 with PTT scripts
Version 4.4.4 supports now PTT scripting. PTT scripts for cocoaModem were added. You have to configure the PTT in the Preferences under the Digi tab. The RTTY setting will be used when commanded by AppleScripts!
Download the application, including cocoaModem PTT scripts: http://www.dl2rum.de/rumsoft/RUMlogApp.zip
