two instance of the log
Jacques
Unread post by Jacques »
Hello
is it possible to have one log under call A and also have a different log under call B ? or must I run two separate instance of rumlog on the same computer.
I cannot find info so far Thank you
Re: two instance of the log
No!
Running multiple instances is strongly discouraged.
Jacques
Noted thank you
