is there an other hotkey than Command-W to erase the QSO data from the input fields?
This is so close to Command-Q and I keep terminating the application which is quite interesting in contest.
DL2RUM wrote: ↑Sun 27. Oct 2024, 15:56
Use the System Preferences to change menu short cuts.
Thanks for the quick answer, Tom.
Sorry to ask: how exactly would you do that? Because I think there is not really a menu item for that what Command-W does.
