Hotkey to clear inout QSO data
DC1LEX
Unread post by DC1LEX »
Hi there,
is there an other hotkey than Command-W to erase the QSO data from the input fields?
This is so close to Command-Q and I keep terminating the application which is quite interesting in contest. :)
Alex, DC1LEX
Re: Hotkey to clear inout QSO data
Use the System Preferences to change menu short cuts.
DC1LEX
DL2RUM wrote: Sun 27. Oct 2024, 15:56 Use the System Preferences to change menu short cuts.
Thanks for the quick answer, Tom.
Sorry to ask: how exactly would you do that? Because I think there is not really a menu item for that what Command-W does.
Alex, DC1LEX
Sure it is. Menu-->Logbook-->Clear
DC1LEX
DL2RUM wrote: Sun 27. Oct 2024, 16:40 Sure it is. Menu-->Logbook-->Clear
Works, entry has to be "Logbook->Clear"
Alex, DC1LEX
