Adding Alarms
Posted: Fri 4. Oct 2024, 09:01
by K4HNT
I know I can add alarms in the Preferences > DX Alarm under callsigns. Is it possible to update this list without manually entering them here? For instance in DX Logger, there is a command line that can be used to add a call its watch list and in Windows, N3FJP this is done by editing a txt file.
My use case is for getting notifications for Current Expeditions and Special Event Stations. For the two logging programs mentioned above, I have written scripts that will scrape the calendar of a popular Expedition site and automatically add the proper calls to be watched In the same manner I can add lists of SES much more efficiently.
Terry K4HNT
Re: Adding Alarms
Posted: Fri 4. Oct 2024, 09:06
by K4HNT
Sorry, even though I searched the forums, I didn't find this thread until after the post DX Alarms callsign imports. However this is from 2017, has anything changed?
Re: Adding Alarms
Posted: Fri 4. Oct 2024, 09:13
Here is an add on (app) to RUMlog for your use case: https://dl2rum.de/RUMlogNG/SeekYou.zip
You can create your own lists with callsign to monitor.
Re: Adding Alarms
Posted: Fri 4. Oct 2024, 22:26
by K4HNT
This looks PERFECT!!! Thank you very much, looking forward to getting into Rumlog more. I enjoy learning the applications and this application is very nicly done. It looks like it fits my needs perfectly, I like to hunt DX, SES stations as well as host SES events and participate in a contest or two. Next week I will be operating as N$F sES for fire prevention week and will be using Rumlog to log the contacts. Hope to work you!
Terry K4HNT
