Crash at start up after upgrade to Ventura 13.6.8 (22G820)
VE3AJ
Unread post by VE3AJ »
RumlogNG crash on startup after upgrade to Ventura 13.6.8 (22G820)
Down loaded fresh copy from Apple and Rumsoft no change
Tried fresh empty log from backup no change
Anyone else having this issue?
Jim
VE3AJ
VE7KAJ
VE3AJ
Re: Crash at start up after upgrade to Ventura 13.6.8 (22G820)
Fixed
macOS corrupted file was issue
Which file was corrupted?
How did you find it out?
How did you fixed it?
The answers of these questions could help others.
VE3AJ
Did not find a specific file
Other programs started failing
macOS was losing desktop settings between boots
Have not done a “clean install” for at least 4 years
Since everything is backed up to external RAID drives
I replaced SSD with a larger one and did a fresh install on the new SSD
No problems since then
