Contest and working someone on a new band
N3RTW
Unread post by N3RTW »
I'm in the K1USN SST right now, and if I work the same person on a new band their info pops up in the received side once I enter their call and hit space... Just like always. However (using ESM) the action is now "Number?" rather than "S&P Message and save".
If I tab through the fields to get to the received number it works as expected, and if I tab out and back in, the Number? changes to S&P Message and Save.
RL 5.15.2 (625) on OSX 14.2.1 M3. I think this worked fine last week in the CWT.
Sean N3RTW
N3RTW
Re: Contest and working someone on a new band
Oh, and normally in ESM mode when I press the enter key on the main keyboard I get the ESM sending and the logging, and when I use the enter key on my numeric keypad it skips the sending and logs. When I get that unexpected Number? prompt, *both* will send the ESM message (aka "Name?") and won't log it.
Opps, you are right. In 5.15.1 I made a change to fix another minor problem. The function to get the suggested rx number is now called with a short delay and asynchron.
It will be fixed in the next version. Tnx for the hint.
