Dx spot don't change frequency on SUNSDR2
Posted: Mon 1. Jan 2024, 11:07
by iu2nub
Good morning and happy new year to all
I'm starting to use Rumlog but I have a problem, certainly due to some lack of mine, but I can't find where it could be.
Rig:Sunsdr2 pro & Expertsdr3 last revision
Rum log configured as per the manual and it works, it receives data from JTDX and/or Gridtraker, but when I double click on a spot to take me to the right frequency, Rumlog receives the callsign and the frequency, but this is not passed to the radio.
The same goes for the dxspots, which aren't displayed on the Expersdr3 screen
Thank you
73 Roberto IU2NUB
Re: Dx spot don't change frequency on SUNSDR2
Posted: Mon 1. Jan 2024, 12:28
Make sure you double click in the Frequency column to qsy.
Do you have followed the instruction here: https://dl2rum.de/RUMlogNG/docs/en/pages/SunFlex.html ?
Posted: Tue 2. Jan 2024, 06:12
by iu2nub
Good morning Thomas
Thanks for the reply
I answer YES to both questions
Or at least for the second one I seem to have followed the manual
You can see everything in the attached image
Thank you
73 Roberto IU2NUB
Posted: Tue 2. Jan 2024, 09:41
Maybe you don't have a connection to your trx. This is not seen in the screen shot.
Posted: Wed 3. Jan 2024, 06:09
by iu2nub
Good morning Thomas
I hope the attached image is ok
Thank you
73 Roberto IU2NUB
Posted: Wed 3. Jan 2024, 09:56
Quick test:
  • The Mode and Frequency labels in the logging mask must be written in green text color.
  • Turn the VFO knob - the frequency read out in RL should follow.
  • Enter 7007 in the Callsign entry field and press Enter - the trx should qsy to 7007 kHz and switch to CW
Check your web socket address and port settings, It seems to be wrong.
Posted: Fri 5. Jan 2024, 07:38
by iu2nub
Thanks Thomas
I found the problem
But I think there is an imperfection in the manual (but I may have misunderstood the manual)
To get everything ok I had to enter the IP of the Mac in the Cat:TCP field, not the Eexpertsdr ip.
73 Roberto IU2NUB
