Spots from N1MM to RunlogNG
Posted: Wed 27. Dec 2023, 23:38
by N1JM
I would like to get spots rom N1MM to show up in the spectrum of NG. Is that possible and if so what are the settings?
73, John N1JM
Re: Spots from N1MM to RunlogNG
Posted: Thu 28. Dec 2023, 00:23
No. What's your use case?
Posted: Sat 30. Dec 2023, 19:38
by N1JM
Ok. I run RumlogNG at the same time I run N1MM on the PC during a contest using an IC-7610. Instead of using the clunky spectrum in N1MM, it would be nice to have spots from N1MM show up in the NG spectrum. I can do something similar using Smart SDR on the Mac for a Flex while running N1MM on the PC.
In settings-UDP what does DX spot (N1MM) do?
73, John N1JM
Posted: Sun 31. Dec 2023, 10:10
It's very similar to the N1MM
spot UDP broadcast with few own extensions. Logbook and contest module have own broadcasts with different parameters.
