Spots from N1MM to RunlogNG
N1JM
Unread post by N1JM »
I would like to get spots rom N1MM to show up in the spectrum of NG. Is that possible and if so what are the settings?
73, John N1JM
Re: Spots from N1MM to RunlogNG
No. What's your use case?
N1JM
Ok. I run RumlogNG at the same time I run N1MM on the PC during a contest using an IC-7610. Instead of using the clunky spectrum in N1MM, it would be nice to have spots from N1MM show up in the NG spectrum. I can do something similar using Smart SDR on the Mac for a Flex while running N1MM on the PC.
In settings-UDP what does DX spot (N1MM) do?
73, John N1JM
It's very similar to the N1MM spot UDP broadcast with few own extensions. Logbook and contest module have own broadcasts with different parameters.
