Short Path and Long Path columms
HK3W
Unread post by HK3W »
Hello Dom, I hope everything is well.
In the "DX Spot" window a column appears with "HDG" short path or "SP" the antenna orientation for DX staition, is it possible for you to add the long path or "LP" column?
Thank you for your excellent work with the RumlogNG program
Best of the best :D
Siso HK3W
