Page 1 of 2
Missing Power Field?
Posted: Tue 15. Aug 2023, 11:13
by G7ORH
Hi, I am new to RUMlog so please excuse me if this has been addressed. I use a MacBook, iPad and iPhone for logging. On the iPad, if I set the default power to power in watts, I do not get an input field. Is this correct or am I missing something?
Re: Missing Power Field?
Posted: Tue 15. Aug 2023, 13:32
Press the Details button for more options.
Posted: Wed 16. Aug 2023, 10:24
by G7ORH
I select ‘Set Details’ and enter power in watts and ensure that the entry has a blue tick, select Okay and nothing happens on the logging screen
Posted: Wed 16. Aug 2023, 21:24
When you have made your selection, you shroud see it:
Posted: Thu 17. Aug 2023, 08:27
by G7ORH
I does not display if I select ‘Power in Watts’, works if ‘High Power’ is selected
Posted: Thu 17. Aug 2023, 09:33
Can you provide screen shots?
Posted: Fri 18. Aug 2023, 10:54
by G7ORH
I did move the blue tick down honest!
Posted: Fri 18. Aug 2023, 13:00
When you select Unknown, no power information will be saved/shown!
Posted: Fri 18. Aug 2023, 15:55
by G7ORH
Apologies Tom,
I got the photos mixed up, doh,
I select ‘set details’, change to blue tick on power in watts and enter a value. Press okay and back to the logging screen and nothing is displayed.
Posted: Fri 18. Aug 2023, 16:09
Okay, I see. It may be a little bit tricky to take over changed data here.
- Enter the Power in Watt
- Select another option, i.e. QRP
- Reselect Power in Watt
