EME Contacts
k1fm
EME Contacts
Unread post by k1fm »
I would like to understand how I am supposed to log EME contacts as I see no options to do that anywhere.
K1FM
Re: EME Contacts
EME is a Propagation mode according to the ADIF specification. Use a user field and set it to <prop_mode>
k1fm
Re: EME Contacts
I hope in future versions propagation modes will be a bit easier to deal with
Thanks for your help
Alain K1FM
Re: EME Contacts
Your suggestions?
I can't see a way to make it easier.
k1fm
Re: EME Contacts
There could be an option to activate an extra column with a selection entry pre-populated with these entries:
https://adif.org/314/ADIF_314.htm#Propa ... numeration
If you activate that, you could select your prop_mode in plain english without touching user settings. Then the program would export ADIF with the appropriate prop_mode tag (EME, ES, ECH AUR etc.) in it.
These modes are rare when considered individually but their cross section might be relevant enough to justify a change, IMHO.
Re: EME Contacts
This is what the user fields are doing!
k1fm
Re: EME Contacts
Sorry I haven't noticed the selection, I though user fields needed to be written manually...
In that case, however, I would have preferred having the description in the selection (rather than the value) but thats a minor detail at this point. Thanks!
