Exception Error and Cab Info Form Problem
Posted: Sun 6. Dec 2009, 01:35
I just used RUMped for my first full contest, Tara Melee.
Worked very well and I am impressed with all it's functionality.
Only two issues came up for me. One in the contest and one when I try to create the Cab file.
The one in the contest is another "exception error when I asked for the "QSO's / Multiplies with dupes" report. It is repeatable.
My work around was not to do that again!
The other problem I am having is probably my fault but when I try to fill out the Cabrillo info sheet there are no contests in the drop down menu. I have this one and the rest in the Plugin folder and Contest Maker sees them but the Cab box doesn't.
In summary though it's was a lot of fun using RUMped and it made the RTTY contest almost too easy!
