Exception Error and Cab Info Form Problem
K6LE
Unread post by K6LE »
I just used RUMped for my first full contest, Tara Melee.
Worked very well and I am impressed with all it's functionality.
Only two issues came up for me. One in the contest and one when I try to create the Cab file.
The one in the contest is another "exception error when I asked for the "QSO's / Multiplies with dupes" report. It is repeatable.
My work around was not to do that again!
The other problem I am having is probably my fault but when I try to fill out the Cabrillo info sheet there are no contests in the drop down menu. I have this one and the rest in the Plugin folder and Contest Maker sees them but the Cab box doesn't.
In summary though it's was a lot of fun using RUMped and it made the RTTY contest almost too easy!
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
Re: Exception Error and Cab Info Form Problem
NIL exception:
Well, there is a bug in RUMped. The fix was easy, but I'm not able to upload it yet, since I have limited internet access today. As workaround use the attached modified contest plug in.
Cabrillo:
There was no contest name given in the plugin using the ContestMaker tool, it's corrected in the attached file.
Put the plugin into the Plugins folder within your RUMped folder.
TARA RTTY Melee NA-side.plist
(14.27 KiB) Downloaded 640 times
Download the latest version of RUMped and the corrected contest templates to avoid these failures:
http://www.dl2rum.de/rumsoft/RUMpedBeta.zip
K6LE
Worked like a champ!
Thanks Tom,
Rick
K6LE
BTW, I am looking forward to using RUMped with the K3 that is half built on my bench!
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
