Problem setting up for CQ WPX RTTY
Posted: Mon 6. Feb 2023, 15:45
I'm working in RUMlogNG version 5.12 and trying to set up for CQ WPX RTTY this coming weekend. It seems to be working fine except for the function key messages. No matter what I try, the program insists on sending every message twice, the second immediately after the first with no break at all between then.
I always contest using ESM and this is where it happens. I decided to try it with ESM not selected, if I do that, the messages are sent properly.
Is there some way to correct this issue that I haven't found?
Thanks for your help.
