Problem setting up for CQ WPX RTTY
K8AJS
Unread post by K8AJS »
I'm working in RUMlogNG version 5.12 and trying to set up for CQ WPX RTTY this coming weekend. It seems to be working fine except for the function key messages. No matter what I try, the program insists on sending every message twice, the second immediately after the first with no break at all between then.
I always contest using ESM and this is where it happens. I decided to try it with ESM not selected, if I do that, the messages are sent properly.
Is there some way to correct this issue that I haven't found?
Thanks for your help.
John Bastin K8AJS
bastinj@gmail.com
Re: Problem setting up for CQ WPX RTTY
Which RTTY interface do you have selected?
K8AJS
I'm using a CAT interface through a USB adapter. The radio is using FSK. This is on my Elecraft K3.
Also, FYl I tried an older RUMlog version. I went back to version 5.9 and it works just fine in this setup. (I had been using 5.11 before I installed version 5.12, but apparently I didn't keep that installer.)
Thanks for any help. 73,
John Bastin K8AJS
bastinj@gmail.com
I'm not be able to reproduce this using the latest version 5.12.1.
