Just downloaded RUMlog; hangs in 10.6.1
K8AJS
Unread post by K8AJS »
I just downloaded RUMlog and am trying to get started with it in Mac OS X 10.6.1 on a MacBook Pro (17-inch Mid 2009).
I start the program, but when I open Preferences the program immediately hangs with a spinning colored wheel, and the only thing I can do is Force Quit RUMlog. Does anyone have it running in Mac OS X 10.6.1 and have any suggestions? I know this isn't much information to go on, but it's about all I have right now. I have and can post the system diagnostic log hang report if it would help.
Mac Book Pro (17-inch Mid 2009), 2.8GHz, 4GB RAM, 500GB hard drive.
Thanks in advance for any help.
John Bastin K8AJS
jbastin@sssnet.com
John Bastin K8AJS
bastinj@gmail.com
Re: Just downloaded RUMlog; hangs in 10.6.1
That's not a good starting point. :cry: :cry: :cry:
Go to your home folder and look for the file „RumLogOwn.plist“ in the /~/library/preferences folder. Delete this file and try again.
K8AJS
DL2RUM wrote:That's not a good starting point. :cry: :cry: :cry:
Thank you, that did the trick.
I set a few preferences and then did an attempt to load my ADIF log from my other computer, but I was getting far too many frequency errors, so I've got to set the QRG/Mode settings and then try it again. I'll get to that when I have an opportunity and see how it goes.
Thanks again!
John Bastin K8AJS
jbastin@sssnet.com
John Bastin K8AJS
bastinj@gmail.com
Louis ON5EN
Unread post by Louis ON5EN »
I see that RumLog does work in 10.6 as well ?
That's good news for me !
73 de Louis ON5EN
Louis ON5EN
RumLog 4.2.4 works vy well under 10.6.2 .
Runs visibly much faster now, but that could just be my new iMac HI !
Did a fresh download & install of Rumlog to be sure.
tnx Tom es 73
ps: managed to get VP2Mxx 3 times, hope you all had a good time & safe trip home.
