Page 1 of 2
globalqsl adif, rumlog adi
Posted: Thu 22. Oct 2009, 18:19
by hb9fmu
Hi there
I am new to rumlog, searched the threads but found no answer to globalqso adif problems.
Globalqsl did not accept the adif files I produced using hand QSL in / QSL print /ADIF.
Globalqso said it only accepts adi. So I changed the suffix manually, but it didn't work either.
Any help?
Many thanks
Best 73s Phil, HB9FMU
Re: globalqsl adif, rumlog adi
Posted: Thu 22. Oct 2009, 18:25
Hi Phil,
are you sure the file is named *.adi not *.adi.adif ? OS-X is doing sometimes crazy things when renaming a file.
With the .adi extension you get the same error message?
Posted: Thu 22. Oct 2009, 18:51
by hb9fmu
Hi Tom
Sorry, it' s the other way round. Rumlog created a file with the suffix adif, which was rejected by globalqsl. So I changed the suffix manually to adi which seemed to work. The upload wasn't rejected anymore but the log could not be processed.
By the way: I am fascinated by your programme! Going to buy a mac mini, so I can use rumlog for DXing at home and I can practise with Morsetrainer and N1MM for our clubevents (no macs there) on the same machine.
73s Phil
Posted: Thu 22. Oct 2009, 18:55
by hb9fmu
Hi Tom
with the adif extension upload doesn't work.
with adi extension, upload takes a long time and I get this message on the website
LOG file uploaded to the server and will be parsed and prepared for the Step 2.
Later I receive an email saying
Lieber HB9CA, leider konnten die Daten aus Ihrem hochgeladenen ADIF File (01-Jan-1970 02:00) nicht in die Datenbank von GlobalQSL aufgenommen werden.
Why the date is set to 1970 I don't know. My mac is properly set.
Posted: Thu 22. Oct 2009, 19:28
Can you e-mail me the adif file please
Irgendwer hat sich mal dieses Feature für Global QSL gewünscht, deshalb denke ich, daß es schon mal funktioniert hat.
Posted: Thu 22. Oct 2009, 20:08
by hb9fmu
Hi Tom
Habe dir die Files eben gemailt.
Vielen Dank!
73s Phil
Posted: Fri 23. Oct 2009, 10:41
Here the corrected version 4.2.1, without the additional '<':
Please test and report.
Download the application only:
http://www.dl2rum.de/rumsoft/RUMlogApp.zip
Posted: Sun 25. Oct 2009, 16:10
by DK5LP
today I upload a file to GlobalQSL:
The file is ok but please change the file-extension from 'adif' to 'adi'.
GlobalQSL accept only files with 'adi '
I think, thats only a little problem ...
Posted: Mon 26. Oct 2009, 03:00
Thanks Karl-Heinz,
I changed the extension to 'adi'. (For the adif export in the Print Window only)
Download the application 4.2.2 only:
Download the full package 4.2.2:
http://www.dl2rum.de/rumsoft/RUMlog.zip
Changes:
http://dl2rum.de/rumsoft/rumlognews.html
Manual:
http://dl2rum.de/rumsoft/RUMlogDoc.html
Posted: Mon 26. Oct 2009, 08:49
by hb9fmu
Hi Karl-Heinz
I tried to upload an adi File with Version 4.2.2
Did not work, globalqsl can't process the file.
I used the QSL-Print Window.
System here: OS X 10.4.11
Did globalqsl accept your upload?
73s Phil, HB9FMU
