globalqsl adif, rumlog adi
hb9fmu
Unread post by hb9fmu »
Hi there
I am new to rumlog, searched the threads but found no answer to globalqso adif problems.
Globalqsl did not accept the adif files I produced using hand QSL in / QSL print /ADIF.
Globalqso said it only accepts adi. So I changed the suffix manually, but it didn't work either.
Any help?
Many thanks
Best 73s Phil, HB9FMU
Re: globalqsl adif, rumlog adi
Hi Phil,
are you sure the file is named *.adi not *.adi.adif ? OS-X is doing sometimes crazy things when renaming a file.
With the .adi extension you get the same error message?
hb9fmu
Hi Tom
Sorry, it' s the other way round. Rumlog created a file with the suffix adif, which was rejected by globalqsl. So I changed the suffix manually to adi which seemed to work. The upload wasn't rejected anymore but the log could not be processed.
By the way: I am fascinated by your programme! Going to buy a mac mini, so I can use rumlog for DXing at home and I can practise with Morsetrainer and N1MM for our clubevents (no macs there) on the same machine.
73s Phil
hb9fmu
Hi Tom
with the adif extension upload doesn't work.
with adi extension, upload takes a long time and I get this message on the website
LOG file uploaded to the server and will be parsed and prepared for the Step 2.
Later I receive an email saying
Lieber HB9CA, leider konnten die Daten aus Ihrem hochgeladenen ADIF File (01-Jan-1970 02:00) nicht in die Datenbank von GlobalQSL aufgenommen werden.
Why the date is set to 1970 I don't know. My mac is properly set.
Can you e-mail me the adif file please
Irgendwer hat sich mal dieses Feature für Global QSL gewünscht, deshalb denke ich, daß es schon mal funktioniert hat.
hb9fmu
Hi Tom
Habe dir die Files eben gemailt.
Vielen Dank!
73s Phil
Here the corrected version 4.2.1, without the additional '<':
Please test and report.
DK5LP
Unread post by DK5LP »
today I upload a file to GlobalQSL:
The file is ok but please change the file-extension from 'adif' to 'adi'.
GlobalQSL accept only files with 'adi ' :o
I think, thats only a little problem ...
vy 73
'Karl'-Heinz, DK5LP / AK5LP
Thanks Karl-Heinz,
I changed the extension to 'adi'. (For the adif export in the Print Window only)
Download the application 4.2.2 only: http://www.dl2rum.de/rumsoft/RUMlogApp.zip
Download the full package 4.2.2: http://www.dl2rum.de/rumsoft/RUMlog.zip
hb9fmu
Hi Karl-Heinz
I tried to upload an adi File with Version 4.2.2
Did not work, globalqsl can't process the file.
I used the QSL-Print Window.
System here: OS X 10.4.11
Did globalqsl accept your upload?
73s Phil, HB9FMU
