IC-7300 Cannot change frequency at the Touchpanel
Posted: Sun 10. Apr 2022, 11:17
by df1bv
I use CAT via USBSerial and "7300-Ctrl" at my 7300. Everything works fine, but I cannot change the band via the touchpanel.
Its only possible to change the Band via the Control Window in RumlogNG.
How can i change it?
73 DF1BV
Re: IC-7300 Cannot change frequency at the Touchpanel
Posted: Sun 10. Apr 2022, 13:13
Which touch panel?
Posted: Sun 10. Apr 2022, 15:32
by df1bv
The Touch Screen at IC7300. If I touch the MHz-Digit, the Band Stacking Register open and immediately close
Posted: Sun 10. Apr 2022, 15:36
by df1bv
Vielleicht hilft das Lesen im Forum. Der Fehler bestand seit vielen Wochen, tritt aber jetzt nicht mehr auf. Vielen Dank für den Support.
Posted: Wed 13. Apr 2022, 10:16
by M0LEP
Yeah, once RUMlogNG is looking after the 7300, you have to do everything via the computer, or else close RUMlogNG and then use the rig directly.
