IC-7300 Cannot change frequency at the Touchpanel
df1bv
Unread post by df1bv »
I use CAT via USBSerial and "7300-Ctrl" at my 7300. Everything works fine, but I cannot change the band via the touchpanel.
Its only possible to change the Band via the Control Window in RumlogNG.
How can i change it?
73 DF1BV
Re: IC-7300 Cannot change frequency at the Touchpanel
Which touch panel?
df1bv
The Touch Screen at IC7300. If I touch the MHz-Digit, the Band Stacking Register open and immediately close
df1bv
Vielleicht hilft das Lesen im Forum. Der Fehler bestand seit vielen Wochen, tritt aber jetzt nicht mehr auf. Vielen Dank für den Support.
M0LEP
Unread post by M0LEP »
Yeah, once RUMlogNG is looking after the 7300, you have to do everything via the computer, or else close RUMlogNG and then use the rig directly.
Rick M0LEP
