RUMlog and POTA
RUMlog and POTA
Karl Heinz, K5KHK wrote an article how to configure RUMlog for POTA activations: http://www.khk.net/wordpress/2020/01/02 ... -for-pota/
Since this site is out of my control, find a copy attached.
Tnx Karl Heinz!
POTA.pdf
(1.67 MiB) Downloaded 1328 times
POTA.pdf
AJ6IY
Re: RUMlog and POTA
Unread post by AJ6IY »
This was an excellent guide - one thing I noticed, however (not specific to this guide) is that RUMlogNG's ADIF export doesn't populate "STATION_CALLSIGN" or "OPERATOR" with normal ADIF export ("Export all QSOs as ADIF") ... in fact, my callsign didn't appear anywhere in the file.
However, if I selected QSOs to export and choose "Export Selected QSOs for special activity", a dialog comes up and I'm able to fill in those fields.
Shouldn't "Export all QSOs as ADIF" do that by default? Perhaps I'm misunderstanding.
PE2V
Re: RUMlog and POTA
Unread post by PE2V »
Thanks!!
N1PCz
Re: RUMlog and POTA
Unread post by N1PCz »
AJ6IY wrote: Wed 20. Apr 2022, 18:41 Shouldn't "Export all QSOs as ADIF" do that by default? Perhaps I'm misunderstanding.
I agree, this is a bit annoying. I use RumLogNG for my FT8/4 POTA activations and until I read that tip I always had to hand edit the ADIF file.
N1PCz
Re: RUMlog and POTA
I never have been able to export from RumLogNG for POTA. I have put the POTA specific data into the user defined tags and no matter what I try they don't export.
How can I get these to export?
Re: RUMlog and POTA
You have to put the information in to the logging mask!
N1PCz
Re: RUMlog and POTA
DL2RUM wrote: Thu 11. Jan 2024, 05:41 You have to put the information in to the logging mask!
How do I do that? I tried pressing the Set button.
Then I tried both exporting and exporting as a special event. My fields still don't show up.
N1PCz
Re: RUMlog and POTA
Oh, I see. The logging mask is the upper screen.
You need to select them, above I've only selected two.
Note: this only applies to future logs, not past logs, which makes sense.
