Memory Pad - Keyboard shortut
wu4g
Unread post by wu4g »
Tried RUMlogNG (5.6.8) for the first time, using it in contest mode for the ARRL 10M contest with my 7300. I 'm now seriously thinking about switching from Windows contest logging to Mac. :) Just got a new M1 Plus MacBook Pro. :D
The only thing I was unable to get to work was the keyboard shortcut Shift-Command-+ to send info from the logging window to the Memory Pad. Using the Contest pulldown to do so worked fine. I checked in System Preferences - Keyboard - Shortcuts and did not find any other app/service using that combination. When I try the keyboard shortcut I see it highlight the CW tab instead of the Contest tab and it increases the keyer (WinKey) speed so seems like it's ignoring the Shift. Tried both left and right Shift keys and neither worked. What am I doing wrong or missing?
Ron
WU4G
Re: Memory Pad - Keyboard shortut
It works as expected here on a German keyboard. I can't test another.
But you can change all the menu short cuts in the System Preferences for your convenience.
