QSL Address label issue
kb9kld
Unread post by kb9kld »
I have run into an issue trying to print address labels with Avery 5160. The labels are offset down and to the right about a 1/4 of an inch and the right sides are cut off. I am using a borderless paper in the print dialog under Paper Handling -> Destination Paper Size, but it still acts like it has a border. The print dialog does not have a specific drop down to choose the paper like Safari does. I printed some earlier this year and I did not have an issue, so I am not sure what may have changed.
Jeff
K9KLD
Re: QSL Address label issue
You have to select your paper in RUMlog Menu-->Edit-->Page Setup first!
kb9kld
Ah, that was the missing step.
Thanks for the quick reply.
Jeff
K9KLD
