First of all, many many thanks for RUMLog
I have an Elecraft K3 and I have set up with the Kenwood 570 without X on or DTR/RTS which should be correct. It does not seem to work too well. If I have the rig on, restart the Mac and open RUMLog, it starts off reading the rig but then forgets. It also seems to forget as soon as I click on a spot in the Bandmap. I also cannot seem to QSY using the cluster spots window).
It works OK using MacLogger and HRD running windows in Boot Camp.
I should also mention that the rig QSY's as it should from the bandmap so something works.
I hope you can help and thanks again.
73 Ian
