100% CPU at idle
N5HC
100% CPU at idle
Unread post by N5HC »
At idle ~100% cpu
Fan runs at a noticeable speed in the computer.
Any idea what to look for? Or is this expected?
RUMLogNG
Version 5.4.2 (475)
Model Name: Mac mini
Model Identifier: Macmini6,2
Processor Name: Quad-Core Intel Core i7
Processor Speed: 2.3 GHz
Number of Processors: 1
Total Number of Cores: 4
L2 Cache (per Core): 256 KB
L3 Cache: 6 MB
Hyper-Threading Technology: Enabled
Memory: 16 GB
Boot ROM Version: 421.0.0.0.0
SMC Version (system): 2.8f0
System Version: macOS 10.15.7 (19H1217)
Kernel Version: Darwin 19.6.0
Boot Volume: Macintosh HD
Boot Mode: Normal
Secure Virtual Memory: Enabled
System Integrity Protection: Enabled
Time since boot: 19:04
Re: 100% CPU at idle
When you receive 50 RBN spots per second or you have two full screen scopes in view, the CPU load will go high.
Without any reason I observed these sometimes when using the iCloud synced logbook. Restarting may help.
N5HC
Turned off iCloud synced logbook.
Restarted the computer.
No CAT connection.
No UDP (at least as I can see)
No DX cluster connected.
Still 100% CPU
Sample of RUMlogNG.txt
(189.85 KiB) Downloaded 456 times
