Frequency in Contest mode
M0TDK
Unread post by M0TDK »
In the contest logging screen, only the band in use appears on screen, although the contest log contains the actual frequency. Is there any way to get the frequency in use on screen in place of just the band? Ideally if there was CAT data coming from the transceiver then the frequency would show, otherwise just the band.
Re: Frequency in Contest mode
The transceiver frequency is show, when available. Furthermore, if you are in Split, the offset will be shown as well.
M0TDK
Sorry, I did not explain clearly what I meant. :D
I would find it useful if the frequency appeared also in the list of QSOs on screen in the contest logging mode.
Current options "Date, Time, Callsign, Band, Mode, Sent, Rcvd, M1, M2, Pts, Note, Op, M3, QSO, Pts 2"
It would be nice if Frequency was included in this list. Also please can you tell me what M1, M2 and M3 are?
Sorry, I misunderstood. You are right, the frequency is not shown in the table.
M2, M2 and M3 stand for three different multipliers.
M0TDK
Thank you very much Tom,
Would it be possible to add frequency to the list at some time in the future?
I enjoy using RumlogNG and I used the previous version as well. Thank you for a great product, and very easy to use. Compared to other loggers on Microsoft platforms it is much more professional and well designed. Thank you. :D
