IC-7300 firmware 1.40
K9QJS
Unread post by K9QJS »
I'm thinking there may not have been enough time w/ version 1.40 to make any needed changes to RUMLogNG to accommodate the new features. I'm observing that the new scroll mode is not working yet. Changing to scroll mode (with a 1 second press of CENT/FIX) will be changed back if RUMLogNG is running at the same time and interfaced to the radio. Unless there is a new setting in RUMLogNG that I am not doing.
Thanks for your support of RUMLogNG.
Hoop K9QJS
K9QJS
Re: IC-7300 firmware 1.40
Thank you forRUMLogNG version 5.3! The improved Icom IC-7300 control panel is great.
As far as I am concerned, your previous version of RUMLogNG showed ICOM what could be done with their radio in terms of the scroll feature. so thank you for, in all likelihood, inspiring Icom for the IC-7300 version 1.40 we have today.
73, Hoop K9QJS
