ic705 control problems on trx2
iz7yfp
Unread post by iz7yfp »
i'm trying version 5.1.1 (455) and ic705 control has a weird problem.
If i configure TX1 everything seems ok, but if i use it on TX2 the program hangs and every application start fails-
(i have to disconnect usb cable)
I'm using the same exact settings..
Thank you for RumLog :)
Re: ic705 control problems on trx2
Tnx for the hint. Try version 5.1.2: https://dl2rum.de/RUMlogNG/RUMlogNG.zip
iz7yfp
i confirm..
5.1.2 is ok :)
Thank you
73 Christian
