is RUMlog NG Big Sur ready?
EA5Q
Unread post by EA5Q »
Does any body know if Big Sur affects RUMlogs normal operation.
Another story will be the USB control of accessories.
Will IC7300 still be directly operative via USB on Big Sur with RUMlogNG?
Thank you!
Re: is RUMlog NG Big Sur ready?
Yes.
Elecraft and Icom will work fine, out of the box. No driver needed. Yaesu may be a problem.
James
Unread post by James »
Since I read that the Yaesu may have a problem, I am delaying the Big Sur update.
I use RumlogNG 5.0.3(437) whit FT-857D and MKIII and it works fine.
What kind of problem can I find?
Greetings and thanks.
KN4SMO
Unread post by KN4SMO »
I am running 5.1.1 RUMlogNG with Big Sur while using a Yaesu FT-991A.
I can not get Control of the radio.
This program has worked in the past using this computer and radio settings?
Do I need to update drivers? It appears not but I am just asking for some direction to fix the issue.
Thanks KN4SMO Scott
Pending on the used chip set in the Yaesu you have to install the correct driver. Check the Si-Labs web site for further information.
Bis Sur will work with all Icoms but not with all Yaesus.
KN4SMO
Hello Again,
Has anyone gotton the Ft-991A to work with Rumlog. I hope I have the latest drivers installed from Is-labs
KN4SMO/ New Call N2OG
KN4SMO
Hello Again,
Yaesu FT-991A now works with Silicon Labs Macintosh OS VCP Driver v6, and the latest Big Sur update which arrived this morning.
