RUMlog 3.10.1 with multiple band maps and more email options
• Support for IC-756PRO III added
• Support for multiple band maps added
The additional band maps have the same features as the "master" band map, except the TRX marker, which one is not shown. The data source for all maps are the same. When you delete a spot in one map, it will disappear from others as well.
BandMapsThree.tiff
BandMapsThree.tiff (148.1 KiB) Viewed 4157 times
BandMapsThree.tiff
Re: RUMlog 3.10.1 with multiple band maps and more email options
In 3.10.1 I have added more e-mail options. In the preferences below the LoTW tab you can select now an SSL option for the direct e-mail output from RUMlog. If you don't like to enter your access data, you can use now the Mail application for sending e-mails.
I was not aware, that some e-mail providers are requesting a SSL connection. Thanks to Lee, WW2DX for the hint.
E-mails are used to send signed Logbook of The World QSO data to the ARRL server or to send a mail for a set e-mail alert after a dx-cluster spot.
