RUMlologNG version 4.5
RUMlogNG 4.5 is available for direct download here:
What's new?
  • Fix: Initialization error K1EL Winkeyer - Tnx Bruce, W4CG
  • Fix: PTT for Contest Voice Keyer - Tnx Jan-Henrik, DK1OM
  • Fix: Cabrillo Soapbox - Tnx Jan-Henrik, DK1OM
  • Fix: Default ITU Zone for CP changed to 14 - Tnx Francesco, IV3TMM
  • New: Transverter support for TRX#1 und TRX# 2
  • New: Support Avery 4780 (48,5 mm x 25,4 mm at DIN A4 4 x 10)
  • New: Support Avery 6032 (63,5 mm x 33,9 mm at DIN A4 3 x 8)
  • New: Unterstützung Club Log Gateway (real-time uploads)
  • New: No CAT data update when Manuel time entry is selected
  • New: Third App Auto Start feature
  • New: Russian World Wide MultiMode Contest
K6UJ
Re: RUMlologNG version 4.5
Unread post by K6UJ »
two questions
I am still using version 4.2
I have been entering the date and time manually.
Today my date isnt showing medium format and I get an orange color in the callsign field.
The user manual says this is because real time isn't checked. How do you check real time ?
I want to continue entering manually.
How do I upgrade to 4.5 and keep my current QSO entry setup ?
thanks,
Bob
K6UJ
The date format can be changed in the Preferences under the General tab.
An orange background in callsign field indicates ab unknown DXCC.
You can update to 4.5 without loosing any setting.
K6UJ
OK, I upgraded to version 4.5 everything looks fine except for the date / time field still.
I have it set to enter manually.
When I enter the date the year shows only one digit. and I still get orange in the callsiign field.
I went to preferences and the date and time are set to medium format. Is there a setting I am missing ?
A screenshot would be helpful. See the System Preferences what you have chosen for your medium date format.
K6UJ
I upgraded from version 4.2 to 4.5. Wow, easy to upgrade ! RumLog is the best logging program I have ever used.
Thanks for making it so easy to use. !
I have a question about entering the time in the time field for a QSO. It is set up for hr/min/sec (03:21:00)
I never enter the seconds. Is there a way to have the field just show hr/min ? (03:21)
thanks,
Bob
K6UJ
No
K6UJ
I can't upload QSO files to LOTW for QSL.
When I click on QSL to LOTW I get this message:
Can't use tqsl:
The file couldn't be opened because it isn't in the correct format.
Should I try to remove and reinstall RunLog ?
Should I try to remove and reinstall RunLog?
No, this won't be helpful. I guess you have a wrong setting. Show us your LoTW Preferences.
K6UJ
I went to preferences and removed and re-entered all the LOTW settings and now it works fine. :-)
Danke !
Bob
K6UJ
