Deleting Entries from Memory Pad
af8a
Unread post by af8a »
Greetings, All - I am running 4.4.1 (370), latest version of Mojave. I do not have a connection to a DX cluster, but I am using the Contest Memory Pad window during a contest (Main Log window is closed - only one Contest Window is being used).
Adding stations is no problem, however, I cannot delete stations from the Memory Pad window. I am holding down the CMD key and clicking on the entry to be deleted, but nothing happens. Is that the correct procedure? Thank you,
Gary AF8A
Re: Deleting Entries from Memory Pad
A station will be removed from the mem pad when you work this station, or after 60 minutes.
