Questions about RumLogNG logging and CAT control
K8CD
Unread post by K8CD »
'm getting set up with RUmLogNG and so far I really like it. However, I'm trying to figure out if there is any way to color code QSO's based upon their LoTW status in the logbook. For example, when I work a station it is marked as 'W', sent to LoTW is 'S', and 'X' is for confirmed in LoTW. Can I color code each of those? It would make looking at the log so much easier than a white wall of text.
Also, I'm using JT Bridge, WSJT-X, and RumLoGNG. Can anyone tell me if there are any benefits to using RumLoGNG with CAT control for the radio?
Re: Questions about RumLogNG logging and CAT control
You should not post your questions everywhere within a short time period! X-posts are never welcome.
Have a look to the QSO Search Window for large logs, or just use the sort feature in the log table. Easy to colorise your desired QSOs.
Which application is doing your CAT control?
K8CD
My apologies. I've removed the FB post.
WSJT-X controls the radio right now. I'm not sure what benefits I obtain by having RumLogNG control the radio.
CAT controls from RUMlog is always possible, regardless of your operating mode.
