Paper QSL out / Add QSL to print queue
SV1QFV
Unread post by SV1QFV »
Is there a way to add QSL to the print queue ?
I can either print one QSL label or select a couple (which is not convenient if you need to scroll over your log).
What i am missing is the same functionality like Add address to print queue on the QSL print.
Any ideas ?
Thanks in advance,
SV1QFV
Re: Paper QSL out / Add QSL to print queue
Normally you do this during qso logging. Set the qsl status to W to put it in the queue. Use Menu-->QSL-->Paper QSLs out for new QSOs
SV1QFV
Thanks that is indeed easier, i have worked a bit with the QSL status and it provides the expected behaviour
SV1QFV
