dxcc.rsd
SV2AEG
dxcc.rsd
Unread post by SV2AEG »
HELLO EVERY ONE
At last days I delete old Rumlog and I downloads the version 5.3.13. At first I open a new log.rsd . Second I open the RUMlog.app. and I see the message " I can't connect the DXCC.rsd base". I try again and again but I have the same message always.
What is the wrong with me?
Thank you for the help. 73 Kostas
Re: dxcc.rsd
The file “DXCC.rsd” must be located in the same folder.
SV2AEG
Re: dxcc.rsd
Yes the file DXCC.rsd is always in the same folder with RUMlog.app,Cluster.rsd, IOTA.rsd, e.t.c
but at the program begin I always have " I can't connect the DXCC.rsd base" and at the Telnet DX Cluster have Unknown country!!
Re: dxcc.rsd
Then the file may be damaged or corrupted.
SV2AEG
Re: dxcc.rsd
Thank you Tom for response
but today I try again new installation and I have the same problem" I can't connect the DXCC.rsd base".I also check K7PT database and always have:
"Can't connect to UCSDB database". What the wrong? My iMac has "macOS High Sierra version 10.13.2". 73!
Re: dxcc.rsd
Show me the contents of the folder where RUMlog is located.
SV2AEG
Re: dxcc.rsd
Re: dxcc.rsd
Looks good. No idea. You should update to NG: https://itunes.apple.com/app/rumlogng/id964454561?mt=12
SV2AEG
Re: dxcc.rsd
Hi Tom
Finally I find the solution to my problem.First I downloading the software and I unzip it into a folder from another pc to a usb stick.After I transfer it to my iMac where it works very well. Maybe the error was to my iMac!
Thank you very much, and all the best. 73 Kostas
