Contest support for OM Activity Contest (OMAC)
om0ayy
Unread post by om0ayy »
    Hi Thomas,
    I would like to ask you for a support of a newly introduced (12/2017) OM Activity Contest (OMAC) is organised for Slovak and Czech stations (OM and OK) only. It has 12 legs, each leg is evaluated separately. It runs Second Saturday of each month: 06:00-07:00 local time - CW, 07:00-08:00 local time - SSB. The contest rules are only in Slovak language (http://omac.telesweb.sk/index.php?referid=5&showid=0&) so here's the brief summary in English (mixed cabrillo fields with a free description):
    1. CATEGORY MODE: CW/SSB
    2. CONTEST: OMAC
    3. CATEGORY BAND: 80M
    • 3520 – 3560 kHz (CW)
      3700 – 3770 kHz (SSB)
    4. Categories:
    • QRO CW + SSB (max. 100 W)
      QRO CW (max. 100 W)
      QRO SSB (max. 100 W)
      QRP CW + SSB (max. 5 W)
      QRP CW (max. 5 W)
      QRP SSB (max. 5 W)
    5. Exchange
    RS or RST + serial nr of QSO starting from 001. Stations in CW+SSB category continue after CW part with next serial nr in SSB part (for example if you worked 30 QSO in CW part, you will start with serial nr 031 in SSB part).
    6. Multipliers:
    Different last letters of the worked callsigns (max. 26). Last letter of the operator’s callsign counts as a multiplier in case there is no worked callsign with such last letter in operator’s log.
    7. Points calculation:
    1 point for each QSO
    1 additional point for each station worked on both modes (CW + SSB)
    8. Result calculation:
    sum of QSO points x sum of multipliers
    Cabrillo example taken from TR4W (please define the category-band and category-mode as mentioned above):
    START-OF-LOG: 3.0
    CREATED-BY: TR4W v.4.49.0
    CALLSIGN: OM3WBY
    CONTEST: OMAC
    CATEGORY-BAND: 80M
    CATEGORY-MODE: SSB
    ADDRESS:  Street 1
    ADDRESS-CITY: Kosice
    ADDRESS-POSTALCODE: 04023
    ADDRESS-COUNTRY: Slovak Republic
    EMAIL: callsign@omradio.sk
    QSO:  3749 PH 2017-12-09 0601 OM3WBY        59  1           OK1AY         59    33        Y
    QSO:  3749 PH 2017-12-09 0601 OM3WBY        59  2           OK1RPS        59     1        S
    QSO:  3749 PH 2017-12-09 0602 OM3WBY        59  3           OM8ON         59    26        N
    QSO:  3749 PH 2017-12-09 0602 OM3WBY        59  4           OM3KWM        59     1        M
    QSO:  3749 PH 2017-12-09 0603 OM3WBY        59  5           OK1JPO        59     1        O
    QSO:  3749 PH 2017-12-09 0603 OM3WBY        59  6           OM8ADU        59     1        U
    QSO:  3749 PH 2017-12-09 0603 OM3WBY        59  7           OK1LST        59     1        T
    QSO:  3749 PH 2017-12-09 0604 OM3WBY        59  8           OK1VHH        59     2        H
    QSO:  3749 PH 2017-12-09 0605 OM3WBY        59  9           OM3WOR        59     4        R
    It would be absolutely perfect to be able to define/customize the contest rules in a text file :). Anyway your program is amazing!!! Very good job!
    Thanks a lot and all the best in 2018!
    73, Pavol OM0AYY
    Re: Contest support for OM Activity Contest (OMAC)
    My to do list is quite long currently, stay tuned.
    om0ayy
    Hi Thomas,
    is there a chance to OM AC will be available soon?
    Thanks a lot.
    73, Pavol
