RUMlogNG 3.7.1 and WSJT-X 1.8.0-rc2 - mode switching
KK7A
Unread post by KK7A »
Hi Tom. The WSJT-X integration is nice in that you no longer need to use JTBridge, but I have a problem.
Whenever my K3s goes from xmit to receive, the mode changes from DATA to LSB. This happens with TUNE, CAT TEST or after the normal XMIT interval from WSJT-X.
As a test, I turned off the integration with RUMlogNG and had WSJT-X talk directly to the K3s and it works fine.
Any ideas on what might be happening?
Thanks, Jim - KK7A
Re: RUMlogNG 3.7.1 and WSJT-X 1.8.0-rc2 - mode switching
Go to the preferences under the trx tab and check the selected mode for PSK. This mode will be used for wsjt.
KK7A
That is exactly what it was, Tom. Thanks for the quick reply!
73, Jim - KK7A
