rumlogng - n1mm
hanz
rumlogng - n1mm
Unread post by hanz »
dear OM,
I'm trying to log the freq, mode and power from my rig and the date from my laptop to rumlogng.
reading the rig details and date from my laptop works fine. Using hamlib and perl.
I try to send via udp a xml like string (n1mm, tried appinfo, radio and contact) to rumlog, udp works fine, tested it.
But some how i do not see any data entering rumlog.
Can you give me a hint or sample how to enter this?
73's hanz
Re: rumlogng - n1mm
There is no provision for that. Logging works from another RUMlog instance only.
You could use an AppleScript to log QSOs from another application.
I did not fully understand your intentions. Why do you want to log from another program? When it's interesting for other users, I'm sure, we will find a solution.
hanz
Re: rumlogng - n1mm
DL2RUM wrote:There is no provision for that. Logging works from another RUMlog instance only.
Hello Tom,
Thanks.
The thing is, i have a ic7300. Like wsjtx/jtbridge after the qso ther's a pop up with the qso detals and this is writte=n to Rumlog. I love this!.
Now when i make a phone qso i would like to get with an app (perl app which i wrote) to get the used frequency, mode and the power from the rig and write, this after only adding the callname, to rum log. This is less "work" then putting freq etc.. by hand.
This was the main idea.
73's hanz
Re: rumlogng - n1mm
You haven't connected the trx to RUMlog? This should be the best solution for most cases.
BTW, the next RUMlog version can log QSOs from WSJT-X directly without JT-Bridge.
hanz
Re: rumlogng - n1mm
DL2RUM wrote:You haven't connected the trx to RUMlog? This should be the best solution for most cases.
Thanks, i haven't did that. I will try.
That would be great that logging can be doen directly from wsjtx.
Thanks for the quick answers.
73's hanz
hanz
Re: rumlogng - n1mm
Thanks Tom,
trx makes live already much easier! Just tested it.
73 hanz
hanz
Re: rumlogng - n1mm
Except, when wsjtx and rumlog are both active wsjtx losses connection.
So i have to switch off rumlog.
Think i stick with the old way.
73's hanz
