RUMlogNG version 2.5
vu2cpl
Re: RUMlogNG version 2.5
Unread post by vu2cpl »
HI Tom, Thanks for the new version. I also had the same key2 problem as mentioned . mine is winkey version 3.
I am also getting an error while trying to upload or download eqsls. The error message says " The certificate for this server is invalid. You might be connecting to a serv"
LOTW works fine for both up/down loads and so is club log.
Any helpful pointers to sort this issue will be appreciated.
Manoj VU2CPL
k4zrj
Unread post by k4zrj »
They seem to be reversed. If I connect the K3 to "Key 1", then in RUMlogNG I must set "Key out 2 enable" in order to key the K3 (and vice versa).
73, Charles, K4ZRJ
I'm 99.7% sure, I have assigned the outputs correct.
The Winkey 2 chip is in a version 1 compatibility mode after start up. In the docs it is not clearly stated, what all is affected. When I have a WK2 chip on my table I will do some tests. For the time being, I will just swap the labels in the preferences. ;-)
NA4M
2.5.1 preferences
Unread post by NA4M »
Updated to 2.5.1 from Ap Store recently. Today I noticed that all my preferences entries are missing with only the defaults shown.
If I add an entry (Name, callsign, etc,) and "Close" preferences and then reopen Preferences my changes are not saved.
No error or warning messages.
Seems like it is not reading my saved preferences and also can't save any changes to it. What am I doing wrong or have messed up?
73 Phil NA4M
Phil, this is a mystery and happens from time to time - even with other apps. At first you should restart the Mac.
Please check Console for messages.
NA4M
Thanks Tom -
I rebooted/powered down & back up my system. Started only RumLog and cleared Console messages. Opened Preferences, added my Call, Name, Grid and then Close prefs and then opened it again gives following Console messages. Prefs changes again not saved.
1/29/16 5:07:17.026 PM RUMlogNG[441]: An uncaught exception was raised
1/29/16 5:07:17.026 PM RUMlogNG[441]: *** -[NSFileManager enumeratorAtURL:includingPropertiesForKeys:options:errorHandler:]: URL is nil
1/29/16 5:07:17.029 PM RUMlogNG[441]: (
1/29/16 5:08:05.426 PM RUMlogNG[441]: An uncaught exception was raised
1/29/16 5:08:05.426 PM RUMlogNG[441]: *** -[NSFileManager enumeratorAtURL:includingPropertiesForKeys:options:errorHandler:]: URL is nil
1/29/16 5:08:05.428 PM RUMlogNG[441]: (
There's a lot more detail in Console messages following the "(" but I didn't paste it in.
RumLogNG while running appears to be using my old saved Prefs based on it's talking OK to K3, DX Cluster, etc.
73 Phil NA4M
